Using Regular Tree Grammars to enhance Sentence Realisation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Natural Language Engineering Année : 2011
Feature-based regular tree grammars (FRTG) can be used to generate the derivation trees of a feature-based tree adjoining grammar (FTAG). We make use of this fact to specify and implement both an FTAG-based sentence realiser and a benchmark generator for this realiser. We argue furthermore that the FRTG encoding enables us to improve on other proposals based on a grammar of TAG derivation trees in several ways. It preserves the compositional semantics that can be encoded in feature-based TAGs; it increases efficiency and restricts overgeneration; and it provides a uniform resource for generation, benchmark construction, and parsing.
nle-final.pdf (148.92 Ko) Télécharger le fichier
inria-00537219 , version 1 (17-11-2010)
Claire Gardent, Benjamin Gottesman, Laura Perez-Beltrachini. Using Regular Tree Grammars to enhance Sentence Realisation. Natural Language Engineering, 2011, Finite State Methods and Models in Natural Language Processing, 17 (2), pp.185-201. ⟨10.1017/S1351324911000076⟩. ⟨inria-00537219⟩
139 Consultations
303 Téléchargements
