A Combined System for Update Logic and Belief Revision - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
In this paper we propose a logical system combining the update logic of A. Baltag, L. Moss and S. Solecki (to which we will refer to by the generic term BMS, [BMS04]) with the belief revision theory as conceived by C. Alchourron, P. Gardenfors and D. Mackinson (that we will call the AGM theory, [GardRott95]) viewed from the point of view of W. Spohn ( [Spohn90], [Spohn88]). We also give a proof system and a comparison with the AGM postulates.
PRIMA_2004.pdf (265.26 Ko) Télécharger le fichier
inria-00537233 , version 1 (17-11-2010)
inria-00537233 , version 2 (08-09-2013)
  • HAL Id : inria-00537233 , version 1
Guillaume Aucher. A Combined System for Update Logic and Belief Revision. PRIMA, Aug 2004, Auckland, New Zealand. pp.1-17. ⟨inria-00537233v1⟩
143 Consultations
613 Téléchargements
