The SIGMOD 2010 Programming Contest: A Distributed Query Engine - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIGMOD record Année : 2010
We report on the second annual ACM SIGMOD programming contest, which consisted in building an efficient distributed query engine on top of an in-memory index. This article is co-authored by the organizers of the competition (Clément Genzmer, Pierre Senellart) and the students who built the two leading implementations (Volker Hudlet, Hyunjung Park, Daniel Schall).
genzmer2010sigmod.pdf (63.2 Ko) Télécharger le fichier
inria-00537237 , version 1 (17-11-2010)
  • HAL Id : inria-00537237 , version 1
Clément Genzmer, Volker Hudlet, Hyunjung Park, Daniel Schall, Pierre Senellart. The SIGMOD 2010 Programming Contest: A Distributed Query Engine. SIGMOD record, 2010. ⟨inria-00537237⟩
169 Consultations
330 Téléchargements
