The SIGMOD 2010 Programming Contest: A Distributed Query Engine
We report on the second annual ACM SIGMOD programming contest, which consisted in building an efficient distributed query engine on top of an in-memory index. This article is co-authored by the organizers of the competition (Clément Genzmer, Pierre Senellart) and the students who built the two leading implementations (Volker Hudlet, Hyunjung Park, Daniel Schall).
Base de données [cs.DB]
