Interactive Global and Local Deformations for Virtual Clay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Making virtual modeling as easy and intuitive as realclay manipulation is still an unsolved problem. This paper takes a step in this direction: in addition to offering standard features such as addition and removal of material, it uses a new real-time plasticity model to let the user apply local and global deformations such as those made in real clay by pressing with a finger or bending a sculpture with one hands. Although not completely physically accurate, the model exhibits several important features of real clay, namely plasticity, mass conservation, and surface tension effects. These features make the model intuitive, since the user obtains the shapes he expects, as demonstrated by our results.
dewaeleg_clay.pdf (1.27 Mo) Télécharger le fichier
Add-rem.avi (987.5 Ko) Télécharger le fichier
Ball.avi (681 Ko) Télécharger le fichier
Bend.avi (883 Ko) Télécharger le fichier
Hole.avi (969.5 Ko) Télécharger le fichier
Layer.avi (1.1 Mo) Télécharger le fichier
Print.avi (620.5 Ko) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00537478 , version 1 (18-11-2010)
Guillaume Dewaele, Marie-Paule Cani. Interactive Global and Local Deformations for Virtual Clay. 11th Pacific Conference on Computer Graphics and Applications (Pacific Graphics 2003), Oct 2003, Canmore, Canada. pp.131 - 140, ⟨10.1109/PCCGA.2003.1238255⟩. ⟨inria-00537478⟩
326 Consultations
374 Téléchargements
