Animating Prairies in Real-Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Generation of dynamic natural scenes is essential for real-time applications, such as simulators or video-games. This paper presents a method for animating and rendering a prairie in real time. The geometric model for the grass relies on three different levels of detail: 3D geometry, volumetric textures (called here 2.5D representation), and 2D textures. The animation of these LODs is controlled through procedural animation primitives that implement wind effects such as slight breeze, gust of wind, whirlwind, or blast of air due to a flying object. Smooth transitions between levels of detail are computed ``on the fly'' according to camera motion, without stopping the animation. We discuss real-time performance on two platforms: an SGI O2, and an ONYX 2 with an Infinite Reality board.
paper.pdf (1.19 Mo) Télécharger le fichier
Format : Figure, Image
inria-00537502 , version 1 (18-11-2010)
Frank Perbet, Marie-Paule Cani. Animating Prairies in Real-Time. ACM-SIGGRAPH Symposium on Interactive 3D Graphics (I3D'01), Mar 2001, Chapel Hill, United States. pp.103-110, ⟨10.1145/364338.364375⟩. ⟨inria-00537502⟩
180 Consultations
370 Téléchargements
