Animating Soft Substances with Implicit Surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1995
This paper presents a hybrid model for animation of soft inelastic substance which undergo topological changes, e.g. separation and fusion and which fit with the objects they are in contact with. The model uses a particle system coated with a smooth iso-surface that is used for performing collision detection, precise contact modeling and integration of response forces. The animation technique solves three problems inherent in implicit modeling. Firstly, local volume controllers are defined to insure constant volume deformation, even during highly inelastic processes such as splitting or fusion. Secondly, we avoid unwanted distance blending between disconnected pieces of the same substance. Finally, we simulate both collisions and progressive merging under compression between implicit surfaces that do not blend together. Parameter tuning is facilitated by the layered model and animation is generated at interactive rates.
SoftSubstances.pdf (111.5 Ko) Télécharger le fichier
PreviousModel.mov (4.37 Mo) Télécharger le fichier
Splitting.mov (1.01 Mo) Télécharger le fichier
SplittingAndFusion.mov (719.48 Ko) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
inria-00537542 , version 1 (18-11-2010)
Mathieu Desbrun, Marie-Paule Cani. Animating Soft Substances with Implicit Surfaces. The 22nd Annual Conference on Computer Graphics (SIGGRAPH'95), ACM SIGGRAPH, Aug 1995, Los Angeles, United States. pp.287--290, ⟨10.1145/218380.218456⟩. ⟨inria-00537542⟩
218 Consultations
297 Téléchargements
