An implicit formulation for precise contact modeling between flexible solids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1993
This paper presents an implicit deformable model, based on isosurfaces of potential fields generated by skeletons, that provides elegant and unified formulations for both geometric parameters such as shape or deformation and physical properties such as rigidity. The model is especially designed to improve collision and contact processing for non-rigid objects. In particular, it generates and maintains exact contact surfaces during interactions.
can93_complete.pdf (3.15 Mo) Télécharger le fichier
balchoc0.mpg (91.19 Ko) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00537550 , version 1 (18-11-2010)
Marie-Paule Cani. An implicit formulation for precise contact modeling between flexible solids. 20th annual conference on Computer graphics and interactive techniques (SIGGRAPH '93)), ACM, Aug 1993, Anaheim, United States. pp.313--320, ⟨10.1145/166117.166157⟩. ⟨inria-00537550⟩
323 Consultations
635 Téléchargements
