Leveraging Software Architectures to Guide and Verify the Development of Sense/Compute/Control Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A software architecture describes the structure of a computing system by specifying software components and their interactions. Mapping a software architecture to an implementation is a well known challenge. A key element of this mapping is the architecture's description of the data and control-flow interactions between components. The characterization of these interactions can be rather abstract or very concrete, providing more or less implementation guidance, programming support, and static verification. In this paper, we explore one point in the design space between abstract and concrete component interaction specifications. We introduce a notion of behavioral contract that expresses the set of allowed interactions between components, describing both data and control-flow constraints. This declaration is part of the architecture description, allows generation of extensive programming support, and enables various verifications. We instantiate our approach in an architecture description language for the domain of Sense/Compute/Control applications, and describe associated compilation and verification strategies.
icse2011.pdf (238.58 Ko) Télécharger le fichier
inria-00537789 , version 1 (28-05-2011)
inria-00537789 , version 2 (13-09-2011)
  • HAL Id : inria-00537789 , version 1
Damien Cassou, Emilie Balland, Charles Consel, Julia Lawall. Leveraging Software Architectures to Guide and Verify the Development of Sense/Compute/Control Applications. ICSE'11: Proceedings of the 33rd International Conference on Software Engineering, May 2011, Honolulu, United States. pp.431-440. ⟨inria-00537789v1⟩
550 Consultations
826 Téléchargements
