Certified Result Checking for Polyhedral Analysis of Bytecode Programs - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2010
Static analysers are becoming so complex that it is crucial to ascertain the soundness of their results in a provable way. In this paper we develop a certified checker in Coq that is able to certify the results of a polyhedral array-bound analysis for an imperative, stack-oriented bytecode language with procedures, arrays and global variables. The checker uses, in addition to the analysis result, certificates which at the same time improve efficiency and make correctness proofs much easier. In particular, our result certifier avoids complex polyhedral computations such as convex hulls and is using easily checkable inclusion certificates based on Farkas lemma. Benchmarks demonstrate that our approach is effective and produces certificates that can be efficiently checked not only by an extracted Caml checker but also directly in Coq.
main.pdf (223.45 Ko) Télécharger le fichier
Dates and versions
inria-00537816 , version 1 (19-11-2010)
Identifiers
  • HAL Id : inria-00537816 , version 1
Cite
Frédéric Besson, Thomas Jensen, David Pichardie, Tiphaine Turpin. Certified Result Checking for Polyhedral Analysis of Bytecode Programs. The 5th International Symposium on Trustworthy Global Computing (TGC), 2010, Munich, Germany. ⟨inria-00537816⟩
201 View
140 Download
Share
