DISC-SET: Handling temporal and security aspects in the Web services composition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ehtesham Zahoor
  • Fonction : Auteur
  • PersonId : 855182
Olivier Perrin
  • Fonction : Auteur
  • PersonId : 755677
  • IdRef : 171122291
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
In this paper we propose the DISC-SeT framework to handle the representation, solution computation and verification of temporal and security requirements in the services composition. The proposed approach provides a flexible event calculus based composition design, that allows for modeling different temporal (response time, time-units and other) and security aspects (access control, confidentiality and others) for Web services with different synchronization modes. The use of a formal approach allows to reason about and verify the security and temporal requirements. Further, as the proposed approach is integrated and builds upon the DISC framework, it allows to learn from run-time security and temporal constraints violations to take recovery actions.
Web
DISC-SET.pdf (150.6 Ko) Télécharger le fichier
inria-00537976 , version 1 (04-12-2010)
  • HAL Id : inria-00537976 , version 1
Ehtesham Zahoor, Olivier Perrin, Claude Godart. DISC-SET: Handling temporal and security aspects in the Web services composition. ECOWS 2010 - The 8th IEEE European Conference on Web Services, Dec 2010, Ayia Napa, Cyprus. ⟨inria-00537976⟩
114 Consultations
122 Téléchargements
