Experiments in Vision-Laser Fusion using the Bayesian Occupancy Filter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Occupancy Grids have been used to represent the environment for some time. More recently, the Bayesian Occupancy Filter (BOF), which provides both an estimate of likelihood of occupancy of each cell, AND a probabilistic estimate of the velocity of each cell in the grid, has been introduced and patented. This work presents the first experiments in the use of the BOF to fuse data obtained from stereo vision and multiple laser sensors, on an intelligent vehicle platform. The paper describes the experimental platform, the approach to sensor fusion, and shows results from data captured in real traffic situations.
ISER_paper_FINAL.pdf (252.34 Ko) Télécharger le fichier
inria-00538678 , version 1 (23-12-2010)
  • HAL Id : inria-00538678 , version 1
John-David Yoder, Mathias Perrollaz, Igor Paromtchik, Yong Mao, Christian Laugier. Experiments in Vision-Laser Fusion using the Bayesian Occupancy Filter. International Symposium on Experimental Robotics, Dec 2010, Delhi, India. ⟨inria-00538678⟩
252 Consultations
295 Téléchargements
