Certified Static Analysis by Abstract Interpretation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
A certified static analysis is an analysis whose semantic validity has been formally proved correct with a proof assistant. We propose a tutorial on building a certified static analysis in Coq. We study a simple bytecode language for which we propose an interval analysis that allows to verify statically that no array-out-of-bounds accesses will occur.
main.pdf (302.8 Ko) Télécharger le fichier
inria-00538753 , version 1 (23-11-2010)
  • HAL Id : inria-00538753 , version 1
Frédéric Besson, David Cachera, Thomas Jensen, David Pichardie. Certified Static Analysis by Abstract Interpretation. Foundations of Security Analysis and Design V (FOSAD), 2009, Bertinoro, Italy. pp.223-257. ⟨inria-00538753⟩
290 Consultations
343 Téléchargements
