A simple and fast 2-approximation algorithm for the one warehouse multi-retailer problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider a well-known NP-hard deterministic inventory control problem: the One-Warehouse Multi-Retailer (OWMR) problem. We present a simple combinatorial algorithm to recombine the optimal solutions of the natural single-echelon inventory subproblems into a feasible solution of the OWMR problem. This approach yields a 3approximation. We then show how this algorithm can be improved to a 2-approximation by halving the demands at the warehouse and at the retailers in the subproblems. Both algorithms are purely combinatorial and can be implemented to run in linear time for traditional linear holding costs and quadratic time for more general holding cost structures. We finally show that our technique can be extended to the Joint Replenishment Problem (JRP) with backorders and to the OWMR problem with non-linear holding costs.
Fichier non déposé
inria-00539042 , version 1 (23-11-2010)
  • HAL Id : inria-00539042 , version 1
Gautier Stauffer, Guillaume Massonnet, Christophe Rapine, Jean-Philippe Gayon. A simple and fast 2-approximation algorithm for the one warehouse multi-retailer problem. Proceedings of the ACM-SIAM Symposium on Discrete Algorithms (SODA) 2011, Jan 2011, San Francisco, United States. ⟨inria-00539042⟩
200 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
