Optimal Eta pairing on supersingular genus-2 binary hyperelliptic curves
This article presents a novel optimal pairing over supersingular genus-2 binary hyperelliptic curves. Starting from Vercauteren's work on optimal pairings, we describe how to exploit the action of the 2^{3m}-th power Verschiebung in order to further reduce the loop length of Miller's algorithm compared to the genus-2 Eta-T approach. As a proof of concept, we detail an optimized software implementation and an FPGA accelerator for computing the proposed optimal Eta pairing on a genus-2 hyperelliptic curve over F_{2^{367}} , which satisfies the recommended security level of 128 bits.
