Optimal Eta pairing on supersingular genus-2 binary hyperelliptic curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article presents a novel optimal pairing over supersingular genus-2 binary hyperelliptic curves. Starting from Vercauteren's work on optimal pairings, we describe how to exploit the action of the 2^{3m}-th power Verschiebung in order to further reduce the loop length of Miller's algorithm compared to the genus-2 Eta-T approach. As a proof of concept, we detail an optimized software implementation and an FPGA accelerator for computing the proposed optimal Eta pairing on a genus-2 hyperelliptic curve over F_{2^{367}} , which satisfies the recommended security level of 128 bits.
genus2.pdf (246.74 Ko) Télécharger le fichier
inria-00540002 , version 1 (25-11-2010)
  • HAL Id : inria-00540002 , version 1
Diego Aranha, Jean-Luc Beuchat, Jérémie Detrey, Nicolas Estibals. Optimal Eta pairing on supersingular genus-2 binary hyperelliptic curves. Cryptographer's Track at the RSA Conference 2012 (CT-RSA 2012), Feb 2012, San Francisco, United States. pp.19. ⟨inria-00540002⟩
243 Consultations
302 Téléchargements
