A Low-Cost Global Network for Data Collection and Query - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Audrey Colbrant
  • Fonction : Auteur
  • PersonId : 883785
Jacques Lemordant
  • Fonction : Auteur
  • PersonId : 844754
We present two complementary research ideas and a prototype framework based on these ideas. The first idea is that by using semantic URIs, Xquery and XML Data Models, HTTP Responses with embedded URIs, it should be possible to construct easily rich web services over SMS for data collection and query. The second idea is that by using several mobile SMS-Web gateways, we can build a low-cost global network with these rich web services. Hospitals in India, including Delek Hospital of Dharamsala, are using the DOTS protocol of the World Health Organisation to fight tuberculosis in Tibetan settlements located in India and Nepal. Our prototype framework implements this protocol.
ExtremeCom10.pdf (414.2 Ko) Télécharger le fichier
inria-00540372 , version 1 (01-12-2010)
  • HAL Id : inria-00540372 , version 1
Audrey Colbrant, Jacques Lemordant, Phuntsok Dorjee. A Low-Cost Global Network for Data Collection and Query. 2nd Extreme Workshop on Communication, Sep 2010, Dharamsala, India. http://www.cs.st-andrews.ac.uk/~fehmi/extremecom/2010/program.html. ⟨inria-00540372⟩
138 Consultations
96 Téléchargements
