Condensed Mitotic Chromosome Structure at Nanometer Resolution Using PALM and EGFP- Histones - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles PLoS ONE Year : 2010
Photoactivated localization microscopy (PALM) and related fluorescent biological imaging methods are capable of providing very high spatial resolutions (up to 20 nm). Two major demands limit its widespread use on biological samples: requirements for photoactivatable/photoconvertible fluorescent molecules, which are sometimes difficult to incorporate, and high background signals from autofluorescence or fluorophores in adjacent focal planes in three-dimensional imaging which reduces PALM resolution significantly. We present here a high-resolution PALM method utilizing conventional EGFP as the photoconvertible fluorophore, improved algorithms to deal with high levels of biological background noise, and apply this to imaging higher order chromatin structure. We found that the emission wavelength of EGFP is efficiently converted from green to red when exposed to blue light in the presence of reduced riboflavin. The photon yield of redconverted EGFP using riboflavin is comparable to other bright photoconvertible fluorescent proteins that allow < 20 nm resolution. We further found that image pre-processing using a combination of denoising and deconvolution of the raw PALM images substantially improved the spatial resolution of the reconstruction from noisy images. Performing PALM on Drosophila mitotic chromosomes labeled with H2AvD-EGFP, a histone H2A variant, revealed filamentous components of ~70 nm. This is the first observation of fine chromatin filaments specific for one histone variant at a resolution approximating that of conventional electron microscope images (10–30 nm). As demonstrated by modeling and experiments on a challenging specimen, the techniques described here facilitate super-resolution fluorescent imaging with common biological samples.
Dates and versions
inria-00541020 , version 1 (29-11-2010)
Identifiers
Cite
Atsushi Matsuda, Lin Shao, Jérôme Boulanger, Charles Kervrann, Peter M. Carlton, et al.. Condensed Mitotic Chromosome Structure at Nanometer Resolution Using PALM and EGFP- Histones. PLoS ONE, 2010, 5 (9), pp.e12768. ⟨10.1371/journal.pone.0012768⟩. ⟨inria-00541020⟩
163 View
0 Download
Share
Gmail Mastodon Facebook X LinkedIn More
