A Survey on Distributed Estimation and Control Applications Using Linear Consensus Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Book Sections Year : 2011
Federica Garin
In this chapter we present a popular class of distributed algorithms, known as linear consensus algorithms, which have the ability to compute the global average of local quantities. These algorithms are particularly suitable in the context of multi-agent systems and networked control systems, i.e. control systems that are physically distributed and cooperate by exchanging information through a communication network. We present the main results available in the literature about the analysis and design of linear consensus algorithms,for both synchronous and asynchronous implementations. We then show that many control, optimization and estimation problems such as least squares, sensor calibration, vehicle coordination and Kalman filtering can be cast as the computation of some sort of averages, therefore being suitable for consensus algorithms. We finally conclude by presenting very recent studies about the performance of many of these control and estimation problems, which give rise to novel metrics for the consensus algorithms. These indexes of performance are rather different from more traditional metrics like the rate of convergence and have fundamental consequences on the design of consensus algorithms.
Dates and versions
inria-00541057 , version 1 (29-11-2010)
Identifiers
Cite
Federica Garin, Luca Schenato. A Survey on Distributed Estimation and Control Applications Using Linear Consensus Algorithms. Alberto Bemporad and Maurice Heemels and Mikael Johansson. Networked Control Systems, 406, Springer, pp.75-107, 2011, Lecture Notes in Control and Information Sciences, ⟨10.1007/978-0-85729-033-5_3⟩. ⟨inria-00541057⟩
867 View
0 Download
Share
