Why and How to Use Arbitrary Precision - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computing in Science and Engineering Année : 2010
Although double precision is usually enough, arbitrary precision increases accuracy and the reproducibility of floating-point computations.
inria-00543927 , version 1 (06-12-2010)
Kaveh R. Ghazi, Vincent Lefèvre, Philippe Théveny, Paul Zimmermann. Why and How to Use Arbitrary Precision. Computing in Science and Engineering, 2010, 12 (3), pp.62-65. ⟨10.1109/MCSE.2010.73⟩. ⟨inria-00543927⟩
146 Consultations
0 Téléchargements
