A reconstruction of the tables of Rheticus' <i>Opus Palatinum</i> (1596) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
A reconstruction of the tables of Rheticus' Opus Palatinum (1596)
This document is a reconstruction of the tables of Rheticus' ''Opus palatinum.'' These tables, published in 1596, were a extension of Rheticus' previous work to a 10 seconds tabulation.
rheticus1596doc.pdf (8.25 Mo) Télécharger le fichier
inria-00543932 , version 1 (06-12-2010)
inria-00543932 , version 2 (01-09-2021)
  • HAL Id : inria-00543932 , version 1
Denis Roegel. A reconstruction of the tables of Rheticus' Opus Palatinum (1596). [Research Report] 2010. ⟨inria-00543932v1⟩
287 Consultations
362 Téléchargements
