Oracle estimators for the benchmarking of source separation algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Signal Processing Année : 2007
Source separation is a difficult problem for which many algorithms have been proposed. In this article, we define oracle estimators which compute the best performance achievable by different classes of algorithms on a given mixture, in a theoretical evaluation framework where the reference sources are available. We describe explicit oracle estimators for three particular classes of algorithms: multichannel time-invariant filtering, single-channel time-frequency masking and multichannel time-frequency masking. We evaluate their performance on various audio mixtures and study their robustness. We draw several conclusions for their three typical applications, namely providing performance bounds for existing and future blind algorithms, selecting the best class of algorithms for a given mixture and assessing the separation difficulty. In particular, we show that it is worth developing blind time-frequency masking algorithms relaxing the common assumption of a single active source per time-frequency point.
vincent_SigPro07.pdf (284.43 Ko) Télécharger le fichier
inria-00544194 , version 1 (07-12-2010)
  • HAL Id : inria-00544194 , version 1
Emmanuel Vincent, Rémi Gribonval, Mark D. Plumbley. Oracle estimators for the benchmarking of source separation algorithms. Signal Processing, 2007, 87 (8), pp.1933--1950. ⟨inria-00544194⟩
372 Consultations
1379 Téléchargements
