Transcription of vocal melodies using voice characteristics and algorithm fusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2006
This paper deals with the transcription of vocal melodies in music recordings. The proposed system relies on two distinct pitch estimators which exploit characteristics of the human singing voice. A Hidden Markov Model (HMM) is used to fuse the pitch estimates and make voicing decisions. The resulting performance is evaluated on the MIREX 2006 Audio Melody Extraction data.
sutton_MIREX06.pdf (133.01 Ko) Télécharger le fichier
inria-00544277 , version 1 (07-12-2010)
  • HAL Id : inria-00544277 , version 1
Christopher Sutton, Emmanuel Vincent, Mark D. Plumbley, Juan P. Bello. Transcription of vocal melodies using voice characteristics and algorithm fusion. 2006. ⟨inria-00544277⟩
88 Consultations
139 Téléchargements
