A Nash bargaining solution for Cooperative Network Formation Games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
The Network Formation problem has received increasing attention in recent years. Previous works have addressed this problem considering only networks designed by selfish users, which can be consistently suboptimal. This paper addresses the network formation issue using cooperative game theory, which permits to study ways to enforce and sustain cooperation among agents. Both the Nash bargaining solution and the Shapley value are widely applicable concepts for solving these games. However, we show that the Shapley value presents three main drawbacks in this context: (1) it is non-trivial to define meaningful characteristic functions for the cooperative network formation game, (2) it can determine for some players cost allocations that can be higher than those at the Nash Equilibrium (and then, if the players refuse to cooperate), and (3) it is computationally very cumbersome. For this reason, we solve the cooperative network formation game using the Nash bargaining solution (NBS) concept. More specifically, we extend the NBS approach to the case of multiple players and give an explicit expression for users' cost allocations. Furthermore, we compare the NBS to the Shapley value and the Nash equilibrium solution, showing its advantages and appealing properties in terms of cost allocation to users and computation time to get the solution. Numerical results demonstrate that the proposed Nash bargaining solution approach permits to allocate costs fairly to users in a reasonable computation time, thus representing a very effective framework for the design of efficient and stable networks.
Le problème de formation des réseaux a reçu une attention croissante ces dernières années. Les travaux précédents ont abordé ce problème compte tenu que les réseaux soient créés par des utilisateurs égoïstes, qui peuvent être constamment sous-optimales. Cet article aborde la question de formation des réseaux en utilisant la théorie des jeux coopératifs, qui permet d'étudier les moyens de faire respecter et de soutenir la coopération entre des agents. Les deux solutions de Nash bargaining et la valeur de Shapley sont largement applicable pour résoudre ces jeux. Cependant, nous montrons que la valeur de Shapley présente trois inconvénients majeurs dans ce contexte : (1) il est non-trivial de définir des fonctions caractéristiques significatives pour le jeu de formation que nous etudions, (2) il peut déterminer des allocations qui sont plus élevés que celles à l'équilibre de Nash (et donc, si les joueurs refusent de coopérer), et (3) le temps de calcul est très long. Pour cette raison, nous résolvons le jeu coopératif de formation de réseau en utilisant le concept de Nash bargaining solution (NBS). Plus spécifiquement, nous étendons l'approche NBS pour le cas de plusieurs joueurs, et nous donnons une expression explicite pour la répartition des coûts des utilisateurs. En outre, nous comparons la NBS à la valeur de Shapley et à l'équilibre de Nash, montrant ses avantages et ses propriétés attrayantes en termes de répartition des coûts pour les utilisateurs et de temps de calcul pour obtenir la solution. Les résultats numériques montrent que l'approche proposée permet de répartir les coûts de manière équitable pour les utilisateurs avec un temps de calcul raisonnables, ce qui représente une solution très efficace pour la conception de réseaux efficaces et stables.
RR-7480.pdf (259.68 Ko) Télécharger le fichier
inria-00544527 , version 1 (08-12-2010)
inria-00544527 , version 2 (10-12-2010)
inria-00544527 , version 3 (07-01-2011)
  • HAL Id : inria-00544527 , version 1
Konstantin Avrachenkov, Jocelyne Elias, Fabio Martignon, Giovanni Neglia, Leon Petrosyan. A Nash bargaining solution for Cooperative Network Formation Games. [Research Report] RR-7480, 2010. ⟨inria-00544527v1⟩
Collections
INRIA-RRRT
439 Consultations
1227 Téléchargements
