MoTIF : an Efficient Algorithm for Learning Translation Invariant Dictionaries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
The performances of approximation using redundant expansions rely on having dictionaries adapted to the signals. In natural high-dimensional data, the statistical dependencies are, most of the time, not obvious. Learning fundamental patterns is an alternative to analytical design of bases and is nowadays a popular problem in the field of approximation theory. In many situations, the basis elements are shift invariant, thus the learning should try to find the best matching filters. We present a new algorithm for learning iteratively generating functions that can be translated at all positions in the signal to generate a highly redundant dictionary.
Jost2006_1450.pdf (174.62 Ko) Télécharger le fichier
inria-00544911 , version 1 (08-02-2011)
Philippe Jost, Pierre Vandergheynst, Sylvain Lesage, Rémi Gribonval. MoTIF : an Efficient Algorithm for Learning Translation Invariant Dictionaries. Acoustics, Speech and Signal Processing, 2006. ICASSP 2006 Proceedings. 2006 IEEE International Conference on, May 2006, Toulouse, France. pp.V -V, ⟨10.1109/ICASSP.2006.1661411⟩. ⟨inria-00544911⟩
563 Consultations
460 Téléchargements
