The PEASS Toolkit - Perceptual Evaluation methods for Audio Source Separation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2010
Niklas Harlander
  • Fonction : Auteur
  • PersonId : 871343
Volker Hohmann
  • Fonction : Auteur
  • PersonId : 871344
We present the PEASS Toolkit designed for the perceptual evaluation of audio source separation. It includes a MUSHRA-based listening-test protocol adapted for the subjective evaluation of audio source separation; a set of subjective measures - sounds and subjective scores - obtained by applying the proposed test protocol; and a set of auditory-motivated objective measures based on a new algorithm to decompose the estimation error into some distortion components (target distortion, interference, artefacts) and on integrating the outputs of the auditory-based objective measure PEMO-Q. This presentation will be the opportunity to detail the recent release of the PEASS toolkit, as well as its use in the Signal Separation Evaluation Campaign (SiSEC) in 2010.
2010-09-27_LVA_PEASS_emiya.pdf (370.71 Ko) Télécharger le fichier
inria-00545477 , version 1 (07-12-2011)
  • HAL Id : inria-00545477 , version 1
Valentin Emiya, Emmanuel Vincent, Niklas Harlander, Volker Hohmann. The PEASS Toolkit - Perceptual Evaluation methods for Audio Source Separation. 9th Int. Conf. on Latent Variable Analysis and Signal Separation, Sep 2010, Saint-Malo, France. 2010. ⟨inria-00545477⟩
535 Consultations
709 Téléchargements
