The DAMNED Simulator for Implementing a Dynamic Model of the Network Controlling Saccadic Eye Movements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The DAMNED simulator is a Distributed And Multithreaded Neural Event-Driven framework designed for implementing Spiking Neuron Networks (SNNs). This paper shows the power of DAMNED for simulating the temporal dynamics of a biologically inspired model of the system controlling saccadic eye movements. A fundamental neural structure for the saccade generation is the Superior Colliculus (SC). The proposed model relies on two pathways leaving this structure: A first one supervises the motor error and the movement initiation and a second one provides a direct drive to premotor centers. This simple model, its SNN implementation and its dynamic behaviour reproduce the evolution of movement amplitude as a function of activity location in the SC. It also accounts for classical results obtained when the SC is subjected to electrical stimulations.
sakad-VFinale.pdf (310.51 Ko) Télécharger le fichier
inria-00545670 , version 1 (11-12-2010)
  • HAL Id : inria-00545670 , version 1
Anthony Mouraud, Hélène Paugam-Moisy, Alain Guillaume. The DAMNED Simulator for Implementing a Dynamic Model of the Network Controlling Saccadic Eye Movements. ICANN'2010, International Conference on Artificial Neural Networks, Sep 2010, Thessaloniki, Greece. ⟨inria-00545670⟩
485 Consultations
207 Téléchargements
