Real-Time Rough Refraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present an algorithm to render objects of transparent materials with rough surfaces in real-time, under distant illumination. Rough surfaces cause wide scattering as light enters and exits objects, which significantly complicates the rendering of such materials. We present two contributions to approximate the successive scattering events at interfaces, due to rough refraction : First, an approximation of the Bidirectional Transmittance Distribution Function (BTDF), using spherical Gaussians, suitable for real-time estimation of environment lighting using pre-convolution; second, a combination of cone tracing and macro-geometry filtering to efficiently integrate the scattered rays at the exiting interface of the object. We demonstrate the quality of our approximation by comparison against stochastic raytracing.
ArticleV208.pdf (10.56 Mo) Télécharger le fichier
SupplementalVideoRRR.avi (32.8 Mo) Télécharger le fichier
videoplayback.flv (12.74 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Vidéo
inria-00545955 , version 1 (13-12-2010)
inria-00545955 , version 2 (13-12-2010)
inria-00545955 , version 3 (14-12-2010)
inria-00545955 , version 4 (07-04-2011)
inria-00545955 , version 5 (07-04-2011)
Charles de Rousiers, Adrien Bousseau, Kartic Subr, Nicolas Holzschuch, Ravi Ramamoorthi. Real-Time Rough Refraction. ACM Siggraph Symposium on Interactive 3D Graphics and Games (I3D), Feb 2011, San Francisco, United States. pp.111-118, ⟨10.1145/1944745.1944764⟩. ⟨inria-00545955v5⟩
1472 Consultations
888 Téléchargements
