Bayesian feature weighting for unsupervised learning, with application to object recognition
We present a method for variable selection/weighting in an unsupervised learning context using Bayesian shrinkage. The basis for the model parameters and cluster assignments can be computed simultaneous using an efficient EM algorithm. Applying our Bayesian shrinkage model to a complex problem in object recognition (Duygulu, Barnard, de Freitas and Forsyth 2002), our experiments yied good results.
