A Unification of Autocalibration Methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
This paper describes a unified theory for autocalibration of a moving camera. The camera models can be 2D projective, 2D affine camera and 1D projective projections. The scenes can be either non-planar scenes or planar scenes and the camera may also undergoes a pure rotation. All these cases are unified into the same framework based on the direction bases. Each formulation on the direction bases is also paralleled with that on projective geometry concepts, essentially encoded by the various forms of the absolute conic. This unification provides not only a common theoretical framework, but also suggests unified parameterisation schema for estimation procedures.
Quan-accv00.pdf (92.85 Ko) Télécharger le fichier
inria-00548291 , version 1 (20-12-2010)
  • HAL Id : inria-00548291 , version 1
Long Quan, Bill Triggs. A Unification of Autocalibration Methods. Asian Conference on Computer Vision (ACCV '00), Jan 2000, Taipei, Taiwan. pp.917--922. ⟨inria-00548291⟩
87 Consultations
79 Téléchargements
