Evaluation of Interest Point Detectors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2000
Many different low-level feature detectors exist and it is widely agreed that the evaluation of detectors is important. In this paper we introduce two evaluation criteria for interest points' repeatability rate and information content. Repeatability rate evaluates the geometric stability under different transformations. Information content measures the distinctiveness of features. Different interest point detectors are compared using these two criteria. We determine which detector gives the best results and show that it satisfies the criteria well.
Schmid-ijcv00.pdf (999.37 Ko) Télécharger le fichier
inria-00548302 , version 1 (22-12-2010)
Cordelia Schmid, Roger Mohr, Christian Bauckhage. Evaluation of Interest Point Detectors. International Journal of Computer Vision, 2000, 37 (2), pp.151--172. ⟨10.1023/A:1008199403446⟩. ⟨inria-00548302⟩
591 Consultations
6550 Téléchargements
