Comparing and Evaluating Interest Points - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
Many computer vision tasks rely on feature extraction. Interest points are such features. This paper shows that interest points are geometrically stable under different transformations and have high information content (distinctiveness). These two properties make interest points very successful in the contest of image matching. To measure these two properties quantitatively, we introduce two evaluation criteria: repeatability rate and information content. The quality of the interest points depends on the detector used. In this paper several detectors are compared according to the criteria specified above. We determine which detector gives the best results and show that it satisfies the criteria well.
schmid_iccv98.pdf (543.37 Ko) Télécharger le fichier
inria-00548328 , version 1 (22-12-2010)
Cordelia Schmid, Roger Mohr, Christian Bauckhage. Comparing and Evaluating Interest Points. 6th International Conference on Computer Vision (ICCV '98), Jan 1998, Bombay, India. pp.230--235, ⟨10.1109/ICCV.1998.710723⟩. ⟨inria-00548328⟩
204 Consultations
862 Téléchargements
