Local Grayvalue Invariants for Image Retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles IEEE Transactions on Pattern Analysis and Machine Intelligence Year : 1997
This paper addresses the problem of retrieving images from large image databases. The method is based on local grayvalue invariants which are computed at automatically detected interest points. A voting algorithm and semilocal constraints make retrieval possible. Indexing allows for efficient retrieval from a database of more than 1,000 images. Experimental results show correct retrieval in the case of partial visibility, similarity transformations, extraneous features, and small perspective deformations.
schmid_pami97.pdf (396 Ko) Télécharger le fichier
Dates and versions
inria-00548358 , version 1 (20-12-2010)
Identifiers
Cite
Cordelia Schmid, Roger Mohr. Local Grayvalue Invariants for Image Retrieval. IEEE Transactions on Pattern Analysis and Machine Intelligence, 1997, 19 (5), pp.530--534. ⟨10.1109/34.589215⟩. ⟨inria-00548358⟩
851 View
2454 Download
Share
