An Egomotion Algorithm Based on the Tracking of Arbitrary Curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1992
We are interested in the analysis of non polyhedral scenes. We will present an original egomotion algorithm, based on the tracking of arbitrary curves in a sequence of gray scale images. This differential method analyses the spatiotemporal surface, and extracts a simple equation relating the motion parameters and measures on the spatiotemporal surface. When a curve contour line is tracked in image sequence, this equation allows to extract the 3D motion parameters of the object attached to the contour when rigid motion is assumed. Experiments on synthetic as well as real data show the validity of this method.
inria-00548441 , version 1 (20-12-2010)
Emmanuel Arbogast, Roger Mohr. An Egomotion Algorithm Based on the Tracking of Arbitrary Curves. European Conference on Computer Vision (ECCV '92), May 1992, Santa Margherita Ligure, Italy. pp.467--475, ⟨10.1007/3-540-55426-2_52⟩. ⟨inria-00548441⟩
36 Consultations
0 Téléchargements
