Generating the initial hypothesis using perspective invariants for a 2D image and 3D model matching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1988
Generation of the initial matching hypothesis for a model-based monocular vision system is presented. The primitive shape description of images is a set of line segments and the model is automatically constructed from a sequence of stereo views. The key points of the approach are the use of vanishing points and other perspective invariants such as collinearity, connectivity, and the use of double ratios to get rid of matching ambiguities.
Fichier non déposé
inria-00548473 , version 1 (20-12-2010)
Long Quan, Roger Mohr, Éric Thirion. Generating the initial hypothesis using perspective invariants for a 2D image and 3D model matching. 9th International Conference on Pattern Recognition (ICPR '88), International Association for Pattern Recognition, Nov 1988, Rome, United States. pp.872--874, ⟨10.1109/ICPR.1988.28386⟩. ⟨inria-00548473⟩
Collections
CNRS UNIV-LORRAINE
82 Consultations
0 Téléchargements
