Learning to Recover 3D Human Pose from Silhouettes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2004
Ankur Agarwal
  • Fonction : Auteur
  • PersonId : 844845
Bill Triggs
We will describe our ongoing work on learning-based methods for recovering 3D human body pose and motion from single images and from monocular image sequences. The methods work directly with raw image observations and require neither an explicit 3D body model nor a prior labelling of body parts in the image.
Triggs-snowbird-abstract.pdf (142.21 Ko) Télécharger le fichier
Triggs-snowbird-talk.pdf (1.98 Mo) Télécharger le fichier
Format : Autre
inria-00548548 , version 1 (20-12-2010)
  • HAL Id : inria-00548548 , version 1
Ankur Agarwal, Bill Triggs. Learning to Recover 3D Human Pose from Silhouettes. Yann LeCun and Yoshua Bengio. Learning 2004 - Abstracts of the 2004 Snowbird Learning Workshop, Apr 2004, Snowbird, United States. 2004. ⟨inria-00548548⟩
226 Consultations
119 Téléchargements
