Human Detection Using Oriented Histograms of Flow and Appearance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Detecting humans in films and videos is a challenging problem owing to the motion of the subjects, the camera and the background and to variations in pose, appearance, clothing, illumination and background clutter. We develop a detector for standing and moving people in videos with possibly moving cameras and backgrounds, testing several different motion coding schemes and showing empirically that orientated histograms of differential optical flow give the best overall performance. These motion-based descriptors are combined with our Histogram of Oriented Gradient appearance descriptors. The resulting detector is tested on several databases including a challenging test set taken from feature films and containing wide ranges of pose, motion and background variations, including moving cameras and backgrounds. We validate our results on two challenging test sets containing more than 4400 human examples. The combined detector reduces the false alarm rate by a factor of 10 relative to the best appearance-based detector, for example giving false alarm rates of 1 per 20,000 windows tested at 8% miss rate on our Test Set 1.
DTS06.pdf (832.93 Ko) Télécharger le fichier
inria-00548587 , version 1 (20-12-2010)
Navneet Dalal, Bill Triggs, Cordelia Schmid. Human Detection Using Oriented Histograms of Flow and Appearance. European Conference on Computer Vision (ECCV '06), May 2006, Graz, Austria. pp.428--441, ⟨10.1007/11744047_33⟩. ⟨inria-00548587⟩
7690 Consultations
6415 Téléchargements
