Dataset issues in object recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2006
Appropriate datasets are required at all stages of object recognition research, including learning visual models of object and scene categories, detecting and localizing instances of these models in images, and evaluating the performance of recognition algorithms. Current datasets are lacking in several respects, and this paper discusses some of the lessons learned from existing efforts, as well as innovative ways to obtain very large and diverse annotated datasets. It also suggests a few criteria for gathering future datasets.
Fichier non déposé
inria-00548595 , version 1 (20-12-2010)
  • HAL Id : inria-00548595 , version 1
Jean Ponce, Tamara Berg, Mark Everingham, David Forsyth, Martial Hebert, et al.. Dataset issues in object recognition. Jean Ponce and Martial Hebert and Cordelia Schmid and Andrew Zisserman. Towards Category-Level Object Recognition, 4170, Springer, pp.29--48, 2006, Lecture Notes in Computer Science (LNCS), 978-3-540-68794-8. ⟨inria-00548595⟩
150 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
