Object Recognition by Integrating Multiple Image Segmentations - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2008
The joint tasks of object recognition and object segmentation from a single image are complex in their requirement of not only correct classification, but also deciding exactly which pixels belong to the object. Exploring all possible pixel subsets is prohibitively expensive, leading to recent approaches which use unsupervised image segmentation to reduce the size of the configuration space. Image segmentation, however, is known to be unstable, strongly affected by small image perturbations, feature choices, or different segmentation algorithms. This instability has led to advocacy for using multiple segmentations of an image. In this paper, we explore the question of how to best integrate the information from multiple bottom-up segmentations of an image to improve object recognition robustness. By integrating the image partition hypotheses in an intuitive combined top-down and bottom-up recognition approach, we improve object and feature support. We further explore possible extensions of our method and whether they provide improved performance. Results are presented on the MSRC 21-class data set and the Pascal VOC2007 object segmentation challenge.
pantofaru_eccv08.pdf (2.76 Mo) Télécharger le fichier
Dates and versions
inria-00548655 , version 1 (20-12-2010)
Identifiers
Cite
Caroline Pantofaru, Cordelia Schmid, Martial Hebert. Object Recognition by Integrating Multiple Image Segmentations. ECCV 2008 - 10th European Conference on Computer Vision, Oct 2008, Marseille, France. pp.481-494, ⟨10.1007/978-3-540-88690-7_36⟩. ⟨inria-00548655⟩
191 View
467 Download
Share
