An Open-Access P300 Speller Database - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2010
The P300 Speller is probably the best known application in BCI [1]. Over the years, many improvements over the pioneering systems have been made and some performance comparisons exist [2]. To contribute to the improvement process, we propose an open access to a large database obtained from first-time users of the P300 speller application implemented within the BCI2000 platform [3] (Figure 1). The database is documented with associated classifier designs and objective performance measures, readily available for comparison and reference. We also propose a set of Matlab functions that help in the preparation of data for alternative classifier design and testing.
BCIposter_final.pdf (567.52 Ko) Télécharger le fichier
inria-00549242 , version 1 (21-12-2010)
  • HAL Id : inria-00549242 , version 1
Claudia Ledesma-Ramirez, Erik Bojorges-Valdez, Oscar Yáñez-Suarez, Carolina Saavedra, Laurent Bougrain, et al.. An Open-Access P300 Speller Database. Fourth International Brain-Computer Interface Meeting, May 2010, Monterey, United States. ⟨inria-00549242⟩
822 Consultations
887 Téléchargements
