The MaggLite Post-WIMP Toolkit: Draw It, Connect It and Run It - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
This article presents MaggLite, a toolkit and sketch-based interface builder allowing fast and interactive design of post-WIMP user interfaces. MaggLite improves design of advanced UIs thanks to its novel mixed-graph architecture that dynamically combines scene-graphs with interaction- graphs. Scene-graphs provide mechanisms to describe and produce rich graphical effects, whereas interaction-graphs allow expressive and fine-grained description of advanced interaction techniques and behaviors such as multiple pointers management, toolglasses, bimanual interaction, gesture, and speech recognition. Both graphs can be built interactively by sketching the UI and specifying the interaction using a dataflow visual language. Communication between the two graphs is managed at runtime by components we call Interaction Access Points. While developers can extend the toolkit by refining built-in generic mechanisms, UI designers can quickly and interactively design, prototype and test advanced user interfaces by applying the MaggLite principle: "draw it, connect it and run it".
MaggLite-UIST2004.pdf (1.31 Mo) Télécharger le fichier
inria-00550595 , version 1 (28-12-2010)
Stéphane Huot, Cédric Dumas, Pierre Dragicevic, Gérard Hégron, Jean-Daniel Fekete. The MaggLite Post-WIMP Toolkit: Draw It, Connect It and Run It. ACM Symposium on User Interface Software and Technology (UIST 2004), 2004, Santa Fe, NM, United States. pp.257-266, ⟨10.1145/1029632.1029677⟩. ⟨inria-00550595⟩
803 Consultations
443 Téléchargements
