High order scheme for compressible turbulent flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The majority of fluid flows that are interesting from a practical point of view are turbulent flows. The problem is that turbulence is particulary difficult to model. Although simulation of turbulent flows has been the topic of important researches, it remains an open issue. We present a stabilized finite element method combine with the one equation Spalart Allmaras model. The aim is to built high order scheme for compressible turbulents flows in order to control numerical dissipation and get accurate solutions.
Fichier non déposé
inria-00551085 , version 1 (02-01-2011)
  • HAL Id : inria-00551085 , version 1
Christelle Wervaecke, Héloïse Beaugendre, Boniface Nkonga. High order scheme for compressible turbulent flows. The Sixth International Conference on Computational Fluid Dynamics, Jul 2010, St. Petersburg, Russia. ⟨inria-00551085⟩
108 Consultations
0 Téléchargements
