Squeak@21c3
This is not a real article. While putting together the demo image for for 21C3, I decided to not write an article that is just to be read (mostly because these are really boring to write...) This text is just a short user manual for that thing (we call it Squeak Image) that I will use for the demo at 21C3. So if you follow the instructions, you will be able to go through the slides and play with everything yourself.
Langage de programmation [cs.PL]
