Temporal Distortion for Animated Transitions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pierre Dragicevic
Waqas Javed
  • Fonction : Auteur
  • PersonId : 889223
Niklas Elmqvist
  • Fonction : Auteur
  • PersonId : 889224
Jean-Daniel Fekete
Animated transitions are popular in many visual applications but they can be difficult to follow, especially when many objects move at the same time. One informal design guideline for creating effective animated transitions has long been the use of slow-in/slow-out pacing, but no empirical data exist to support this practice. We remedy this by studying object tracking performance under different conditions of temporal distortion, i.e., constant speed transitions, slow-in/slow-out, fast-in/fast-out, and an adaptive technique that slows down the visually complex parts of the animation. Slow-in/slowout outperformed other techniques, but we saw technique differences depending on the type of visual transition.
timedistort.pdf (1.86 Mo) Télécharger le fichier
inria-00556177 , version 1 (06-11-2011)
inria-00556177 , version 2 (04-06-2012)
Pierre Dragicevic, Anastasia Bezerianos, Waqas Javed, Niklas Elmqvist, Jean-Daniel Fekete. Temporal Distortion for Animated Transitions. CHI 11: International Conference on Human Factors in Computing Systems, ACM, May 2011, Vancouver, Canada. ⟨10.1145/1978942.1979233⟩. ⟨inria-00556177v1⟩
254 Consultations
565 Téléchargements
