Energy-aware mappings of series-parallel workflows onto chip multiprocessors
This paper studies the problem of mapping streaming appli- cations that can be modeled by a series-parallel graph, onto a 2-dimensional tiled CMP architecture. The objective of the mapping is to minimize the energy consumption, using dynamic and voltage scaling techniques, while maintaining a given level of performance, reflected by the rate of process- ing the data streams. This mapping problem turns out to be NP-hard, but we identify simpler instances, whose optimal solution can be computed by a dynamic programming algo- rithm in polynomial time. Several heuristics are proposed to tackle the general problem, building upon the theoretical results. Finally, we assess the performance of the heuris- tics through comprehensive simulations using the StreamIt workflow suite and various CMP grid sizes.
