A Visual Development Environment for Meta-Computing Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Gaspard is a visual programming environment devoted to the development and control of scientific parallel applications. par The two paradigms of parallel programming (task and data parallelism) are mixed in Gaspard: a hierarchy of task graphs operates on array flows. These two levels are mixed in a common metaphor. An application is designed as a printed circuit: the programmer specifies tasks as boards or chips and instantiates tasks by plugging them into slots. par The number crunching applications developped using Gaspard are deployed on metacomputing platforms. The visual specification of the application mapping may be dynamically modified at runtime according to the information provided by Gaspard.
Fichier non déposé
inria-00565182 , version 1 (11-02-2011)
  • HAL Id : inria-00565182 , version 1
Pierre Boulet, Jean-Luc Dekeyser, Florent Devin, Philippe Marquet. A Visual Development Environment for Meta-Computing Applications. HCI International 2001, 9th Int'l Conf. on Human-Computer Interaction, 2001, New Orleans, Lousiana, United States. ⟨inria-00565182⟩
76 Consultations
0 Téléchargements
