Ego-munities, Exploring Socially Cohesive Person-based Communities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Adrien Friggeri
  • Fonction : Auteur
  • PersonId : 869014
Guillaume Chelius
  • Fonction : Auteur
  • PersonId : 853112
In the last few years, there has been a great interest in detecting overlapping communities in complex networks, which is understood as dense groups of nodes featuring a low outbound density. To date, most methods used to compute such communities stem from the field of disjoint community detection by either extending the concept of modularity to an overlapping context or by attempting to decompose the whole set of nodes into several possibly overlapping subsets. In this report we take an orthogonal approach by introducing a metric, the cohesion, rooted in sociological considerations. The cohesion quantifies the community-ness of one given set of nodes, based on the notions of triangles - triplets of connected nodes - and weak ties, instead of the classical view using only edge density. A set of nodes has a high cohesion if it features a high density of triangles and intersects few triangles with the rest of the network. As such, we introduce a numerical characterization of communities: sets of nodes featuring a high cohesion. We then present a new approach to the problem of overlapping communities by introducing the concept of ego-munities, which are subjective communities centered around a given node, specifically inside its neighborhood. We build upon the cohesion to construct a heuristic algorithm which outputs a node's ego-munities by attempting to maximize their cohesion. We illustrate the pertinence of our method with a detailed description of one person's ego-munities among Facebook friends. We finally conclude by describing promising applications of ego-munities such as information inference and interest recommendations, and present a possible extension to cohesion in the case of weighted networks.
Ces dernières années, l'intérêt pour la détection de communautés recouvrante dans les réseaux réels s'est intensifié. Celles ci sont des groupes de nœuds possédant une forte densité interne et présentant une densité faible vers le reste du réseau. À ce jour, la majorité des méthodes utilisées pour calculer de telles communautés héritent de celles développées dans le domaine de la détection de communautés disjointes, ou bien en étendant le concept de modularité à un contexte recouvrant, ou bien en essayant de décomposer le réseau entier en plusieurs sous ensembles éventuellement recouvrant. Dans ce rapport, nous abordons la question de manière orthogonale en introduisant une mesure, la cohésion, reposant sur des considérations sociologiques. La cohésion permet de quantifier l'aspect communautaire d'un ensemble de nœuds à partir des notions de triangles -- triplets de nœuds interconnectés -- et de liens faibles, au lieu de la vision classique utilisant des arêtes. En substance, nous introduisons une caractérisation numérique des communautés: des ensembles de nœuds possédant une cohésion élevée. Nous présentons ensuite une nouvelle approche au problème des communautés recouvrantes en introduisant le concept d'ego-munauté: des communautés subjectives centrées sur un nœud donné, précisément incluses dans son voisinage. Nous utilisons la cohésion pour élaborer un algorithme heuristique construisant les ego-munautés d'un nœud en tentant de maximiser leur cohésion. Finalement, nous présentons des résultats préliminaires, sous la forme d'une description détaillé des ego-munautés d'amis Facebook d'une personne. Nous concluons en décrivant des applications prometteuses des ego-munautés, par exemple l'inférence d'information sur le sujet ou la recommandation de centre d'intérêt, et présentons une extension possible à la cohésion dans le cas de réseaux pondérés.
RR-7535.pdf (261.67 Ko) Télécharger le fichier
inria-00565336 , version 1 (13-02-2011)
inria-00565336 , version 2 (19-02-2011)
  • HAL Id : inria-00565336 , version 1
  • ARXIV : 1102.2623
Adrien Friggeri, Guillaume Chelius, Eric Fleury. Ego-munities, Exploring Socially Cohesive Person-based Communities. [Research Report] RR-7535, 2011. ⟨inria-00565336v1⟩
Collections
INRIA-RRRT
333 Consultations
264 Téléchargements
