Key Reduction of McEliece's Cryptosystem Using List Decoding
Different variants of the code-based McEliece cryptosystem were pro- posed to reduce the size of the public key. All these variants use very structured codes, which open the door to new attacks exploiting the underlying structure. In this paper, we show that the dyadic variant can be designed to resist all known attacks. In light of a new study on list decoding algorithms for binary Goppa codes, we explain how to increase the security level for given public keysizes. Using the state-of-the-art list decoding algorithm instead of unique decoding, we exhibit a keysize gain of about 4% for the standard McEliece cryptosystem and up to 21% for the adjusted dyadic variant.
