Efficient support for MPI-IO atomicity based on versioning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the challenge of building data management systems that meet an important requirement of today's data-intensive HPC applications: to provide a high I/O throughput while supporting highly concurrent data accesses. In this context, many applications rely on MPI-IO and require atomic, non-contiguous I/O operations that concurrently access shared data. In most existing implementations the atomicity requirement is often implemented through locking-based schemes, which have proven inefficient, especially for non-contiguous I/O. We claim that using a versioning-enabled storage backend has the potential to avoid expensive synchronization as exhibited by locking-based schemes, which is much more efficient. We describe a prototype implementation on top of ROMIO along this idea, and report on promising experimental results with standard MPI-IO benchmarks specifically designed to evaluate the performance of non-contiguous, overlapped I/O accesses under MPI atomicity guarantees.
Fichier non déposé
inria-00565358 , version 1 (11-02-2011)
Viet-Trung Tran, Bogdan Nicolae, Gabriel Antoniu, Luc Bougé. Efficient support for MPI-IO atomicity based on versioning. 11th IEEE/ACM International Symposium on Cluster, Cloud, and Grid Computing (CCGrid 2011), May 2011, Newport Beach, CA, United States. pp.514-523, ⟨10.1109/CCGrid.2011.60⟩. ⟨inria-00565358⟩
168 Consultations
0 Téléchargements
