Walking motion generation with online foot position adaptation based on l1- and l∞-norm penalty formulations
The article presents an improved formulation of an existing model predictive control scheme used to generate online "stable" walking motions for a humanoid robot. We introduce: (i) a change of variable that simplifies the optimiza- tion problem to be solved; (ii) a simply bounded formulation in the case when the positions of the feet are predetermined; (iii) a formulation allowing foot repositioning (when the system is perturbed) based on l1- and l∞-norm minimization; (iv) a formulation that accounts for (approximate) double support constraints when foot repositioning occurs.
Robotique [cs.RO]
